back seat removal/install
back alley
Post by back alley »
ok, i need info. can anyone tell me how to remove the butt part of the back seat? also to install my 'new' back seat do i need any special clips or anything like that? i bought a back seat with better upholstery that mine and now i need to remove & install. thanks!!
Maddbuck
Re: back seat removal/install
Post by Maddbuck »
there are two levers that hold down the back seat just feel under the front of it. Push the two levers and lift it up and out. :roll:
Brainless
Post by Brainless »
So there's no bolts or anything??
Jonathan Michaud
93 Red RS
-=deathtrap-mx3=-
Post by -=deathtrap-mx3=- »
not for the bottom portion of it. i think the back is held by bolts. the online manual shows the locations.
Looking for a 94+GS for KL-ZE fun :)
02 Protege DX Retired
93 MX-3 RS Gone But Not Forgotten
mrspanky79
Post by mrspanky79 »
if it is the same as the 94, the bottom seat is held on by plastic plugs/clips just feel around for them and pull up. The back is held on by four bolts very easy to take out. Hope this helps.
War does not determine who is right, war determine who is left!
94 mx3 GSX Stroked Turbo'd and Intercooled
99 vitara 4x4
back alley
i'm assuming that i can take out the bottom without taking out the back part. is this correct?
mrspanky79
yes and you dont even need tools. Just feel around for the pionts were it is held down and pull up, less then a min to do.
99 vitara 4x4
