2.5 massairflowsensor
im lookn for a 2.5 maf to use for my klze.
- Custommx3
- Site Administrator
Re: 2.5 massairflowsensor
the Ms8 in japan comes with a Je50 VAF, which is what a GS uses stock.
2.5 liter VAF part number KL-02 look on car-part.com, this is only if you are going to use the k8 computer otherwise, what Barry said holds true.
93 Mx-3 GS klze swapped(sold)
96 Integra LS DD
91 Crx Si drag car
2.0L sleeved gsr block, forged internals, skunk2 valvetrain, HP racing intake manifold, Holset H1 turbo, 1000cc injectors, short geared lsd transmission, 3" turboback exhaust. 20 psi![Smile :)](./images/smilies/icon_smile.gif)
96 Integra LS DD
91 Crx Si drag car
right now im using the 2.5 ecu with the 1.8 vaf and my gas milege sucks(150 miles/full tank).maybe changing the maf would solve this problem.( i will be getting the klze ecu later). if you guys have any suggestion, please post. thanks.
I got one when i did the swap then got theze ecu so idont need it, make me an offer.
65 shot > V8
thank you for the reply guys, but i got one from the junkyard for $40.
