94 Mazda 626, V6, 5 spd parts car
1994 Mazda 626 ES parts car, 5 spd, ABS, all ES options. Hit in front but front suspension OK. It is not driveable. Airbags blown. Hood OK.<p>This would be a great car if you wanted to do the I4 to V6 swap and ATX to MTX swap at the same time! Four wheel disc brakes!<p>Has about 140K miles, engine was using some oil prior to accident.<p>Asking $800. You MUST pick up, I will not deliver. Car is in Russellville, Arkansas.<p>[ April 20, 2003: Message edited by: pelado ]</p>
Re: 94 Mazda 626, V6, 5 spd parts car
$700 obo
