Viper Alarm Troubles
Posted: November 16th, 2015, 8:05 pm
by Jovian2k
I am going through inspection in Quebec for my car and installed DRL which was not too difficult, tapped power wire from fuse box under DS dash. Then I went to finish job and reconnect battery my alarm siren keeps going off. The funny thing is no lights blink (like alarm usually does) and the remote pager will not shut alarm off (Viper 791xv) or communicate with car anymore. This is despite everything I have managed to think of...
-change pager battery
-disconnecting neg battery terminal and reconnect
-disconnecting harnesses from alarm brain
-charge battery fully
-regrounding the siren
This is driving me crasy, I have many other repairs to do on my car to get it to pass inspection and I do not need this
Any ideas??
Re: Viper Alarm Troubles
Posted: November 17th, 2015, 6:13 pm
by Daninski
Was this a used alarm? Do you have an installation guide?
Posted: November 17th, 2015, 7:00 pm
by Jovian2k
No was installed new many years ago, I have the installation guide but don't know how to troubleshoot this
Posted: November 17th, 2015, 8:57 pm
by Daninski
I turn my alarm off before I disconnect the battery in the fall. Most alarms I've been told about will self arm if the battery runs low. Sounds like yours may of self armed. Do you not have a valet button with it to kill the alarm? You can call Viper they have a tech line to help you.
Posted: November 17th, 2015, 8:59 pm
by Jovian2k
I'll try to call them, that may have happened, tried to tien of with valet button but no luck
Posted: November 17th, 2015, 9:19 pm
by Daninski
Let me look around I may have my Viper manual, at least then we can see if there's any work around. Like getting in, opening and closing the drivers door, lock/unlock the car, turning the ignition key on and off 5 x,,,,,then again some are less complicated
Posted: November 17th, 2015, 10:04 pm
by Jovian2k
Cool thanks let me know what you find. What's weird is that the alarm doesn't seem to be going off as usual, no lights blinking and pager will not shut it off...
Posted: November 22nd, 2015, 6:30 pm
by Daninski
Funny the wife's Sportage wouldn't crank on Friday ???. I spent a day and a half researching with no help from the Dealership at all (thanks pricks). 2 simple questions that's all I needed answered. After testing things like the start relay and bla bla bla in the end I left the ignition ON for 1 minute and it finally cranked and started. That's suppose to disengage the lock out solenoid, now I still need to identify where the bloody alarm module is so I can by-pass that solenoid. I hate car alarms.
