Hi,
Been having starting problems, the engine turns but there seems to be no ignition until you give it a little throttle then it'll turn over and then idle quite high about 1500 rpm till the engine gets warm then its fine, although it still won't start normally but quicker.
I read that if the mx3's are run out of fuel it messes the fuel injectors up, and this is what the car garage did before I bought it.
I'm yet to change the fuel filter but wondered if this has happened before or is there a way of resetting the ecu etc?
Any help is much appreciated.
Thanks.
starting issues
Re: starting issues
To 'clear' the ECU simply remove the + from the battery and hold the brake pedal down for 15 sec's or so. Have you checked the TPS, it could be way out of adjustment and could effect starting.
