Should I Add The Lucas
Posted: March 14th, 2014, 7:23 pm
by posey92
Changing my manual fluid. I have mobile 1 full synthetic 7590. I was curious of what u guys thought of adding the lucas transmission addative with it...I know my second gear grinds a bit when ahifting into too quickly. Or should I just stick with the fluid alone.
Re: Should I Add The Lucas
Posted: April 6th, 2014, 12:39 am
by zerialz
stick with the oem recommended fluid. mine grinds a bit into 2nd as well.. usually when cold.. figured it's the synchros.. for now i go 1st to 3rd until op temp. i noticed it's nice if i lift the stick into 2nd slowly like you said..
Posted: April 6th, 2014, 1:39 pm
by Sleeper6
I use bg synchroshift, works great. Although really you can use any 75-90 provided it doenst have sulfer, it will kill the brass synchros
