Crossmember Suspension dude?
- DEMBOU
Hello friends, I have a question ...
I had an accident in my MX3 1.6l in the front and I have to change the crossmember Full Suspension, I know that cars are compatible to search junk yards.
This part can be removed completely? there will be some DIY or how to do it?
I have idea that can be 100% compatibe of: 323/Protege/Mx3 (1.6L or 1.8L) all 1990-1994
Is that correct?
I´m talk about this part EA01-34-8006 I can´t paste de picture.... http://www.jimellismazdaparts.com/showA ... tring=cros
Is that correct?
- Josh
Re: Crossmember Suspension dude?
No they are not compatible. The 323 and Protege depending on AWD or FWD are compatible together, but the MX3 is on its own. the only thing that is compatible is the lower A arms and the 323 and Protege are narrower as the MX has a wider stance. If I were you I would measure the mounting holes in the cross member and the distance to the firewall. You may be able to modify it to fit. You can swap yours with a GS, and this would be a big upgrade if you did as the GS has a lower crossmember plate that the RS does not, as well as a tighter steering ratio.
I hope that helps
I hope that helps
- DEMBOU
Ok thanks dude, but i saw in the online manuals and digramas on 323/protege 93, and the crossmember suspension it´s the same part number, that is my question..Josh wrote:No they are not compatible. The 323 and Protege depending on AWD or FWD are compatible together, but the MX3 is on its own. the only thing that is compatible is the lower A arms and the 323 and Protege are narrower as the MX has a wider stance. If I were you I would measure the mounting holes in the cross member and the distance to the firewall. You may be able to modify it to fit. You can swap yours with a GS, and this would be a big upgrade if you did as the GS has a lower crossmember plate that the RS does not, as well as a tighter steering ratio.
I hope that helps
Closer to home there is a salvage shop and they have a GS, I will check if it is fully equal to just remove and replace without any modification.
- Josh
Hmm. I will do some digging tonight and see what I can find. I know they share several parts but I was pretty sure they were a little different.DEMBOU wrote:Ok thanks dude, but i saw in the online manuals and digramas on 323/protege 93, and the crossmember suspension it´s the same part number, that is my question..Josh wrote:No they are not compatible. The 323 and Protege depending on AWD or FWD are compatible together, but the MX3 is on its own. the only thing that is compatible is the lower A arms and the 323 and Protege are narrower as the MX has a wider stance. If I were you I would measure the mounting holes in the cross member and the distance to the firewall. You may be able to modify it to fit. You can swap yours with a GS, and this would be a big upgrade if you did as the GS has a lower crossmember plate that the RS does not, as well as a tighter steering ratio.
I hope that helps
- DEMBOU
Ok thanksJosh wrote:Hmm. I will do some digging tonight and see what I can find. I know they share several parts but I was pretty sure they were a little different.DEMBOU wrote:Ok thanks dude, but i saw in the online manuals and digramas on 323/protege 93, and the crossmember suspension it´s the same part number, that is my question..Josh wrote:No they are not compatible. The 323 and Protege depending on AWD or FWD are compatible together, but the MX3 is on its own. the only thing that is compatible is the lower A arms and the 323 and Protege are narrower as the MX has a wider stance. If I were you I would measure the mounting holes in the cross member and the distance to the firewall. You may be able to modify it to fit. You can swap yours with a GS, and this would be a big upgrade if you did as the GS has a lower crossmember plate that the RS does not, as well as a tighter steering ratio.
I hope that helps
- DEMBOU
Anybody?
OK I was a little confused. EA01-34-800G is the PN, the 6 threw me off.
EA01-34-800H is the GS PN. I should be able to remove this for you. 100 dollars plus shipping seems like a fair price
He has a 4cyl, is the GS V6 crossmember compatible for the 4cyl?
It is compatible. It's preferred because it will have the mountpoints for the crossmember reinforcement.
- Josh
^^^ YES what he said.
94+ RS was rumored to have the holes for the cross member as well, but my 95' does not have them.
Protege should be the same one as well, though make sure you use MX3 A arms as to not change the width as Pro, 323 A arms are shorter.
- DEMBOU
Hi friend , sorry for responding so far, this part EA01-34-800H GS, do not fit with this part that support the front and rear engine mountsSuperK wrote:OK I was a little confused. EA01-34-800G is the PN, the 6 threw me off.
http://i.ebayimg.com/00/s/NzY4WDEwMjQ=/ ... ~60_57.JPG
