If you want to remove your cat on the v6 this is the way to go. Hardware included.takes just a few minutes to swap out. *off road use only* its illegal on the street and will make your car loud. $30 Located in Oakley ca 94561.
-Chris
(925) 565-355two
static_x_@ hotmail.com
[FS] GS Test pipe
- GreenMachine
[FS] GS Test pipe
'92 GS-no lip. Klze. no cat. phenolic spacers. no power steering. no a/c. hei mod. poly filled mounts. probinator chip. loud exhaust. b&m shifter. tokico struts. suspension tech springs. axxis 17 in rims.
'86 mr2-stock and still hauls a-- in curves.
'05 Gsxr-50 tooth stunt bike
![Image](http://myspace-459.vo.llnwd.net/01142/95/48/1142528459_l.jpg)
