Brake lines that are stuck
WhiteFinish
Post by WhiteFinish »
So who has some tips to get this loose?
These things have a 10mm wrench, but they are so stuck that the wrench slips over it and rounds the edges.
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
youdirtyfox
Re: Brake lines that are stuck
Post by youdirtyfox »
sounds like you need a brake line spanner http://www.esska-tech.co.uk/esska_eng_s ... ranke.html
Post by Josh »
At this point It looks like you need a pair of vicegrips...
Evo_Spec
Post by Evo_Spec »
Josh wrote:At this point It looks like you need a pair of vicegrips...
+1
That's what i did with the bleeder screws, just put on some vicegrips so tight that you pretty much need to do it with pliers just to get the vice grip on.
WhiteFinish
What is a brake line spanner? How is it different from a regular wrench?
Worklog click
marcdh
Post by marcdh »
Has only one open end
View Worklog
Post by wytbishop »
Called a flare nut wrench here.
Heating the distribution block that they are screwed into will help.
Silkwyrm
Post by Silkwyrm »
Ah you English and your funny.. English.
Disclaimer:
Those of you not in England, I apologize if the reference offends you. But the linguistic joke doesn't work with the word Brits, or United Kingdomers, err whatever. :)
MrMazda92
Post by MrMazda92 »
Are you asking about the brake lines themselves, or where they mount to the subframe?
If it's the subframe, grind the edges super flat and use an adjustable crescent style wrench to hurk it off.
Evo_Spec
Post by Evo_Spec »
MrMazda92 wrote:Are you asking about the brake lines themselves, or where they mount to the subframe?
he's talking about the brake lines themselves, if you look at his picture the threads on the brake lines are stripped.
mitmaks
Post by mitmaks »
Should've tried soaking them with penetrating fluid like PB Blaster or WD40
MrMazda92
Post by MrMazda92 »
In that case...
Torch + Vicegrip pliers. Replace with factory hardware from a different car, use anti-seize in the future...
WhiteFinish
With some vice grips I've got them loose.
Don't know how to reapply them because it got stripped.
Worklog click
Post by Josh »
WhiteFinish wrote:With some vice grips I've got them loose.
With vice grips ;)
WhiteFinish
Hahaha...
I mean, it isn't possible to change the stripped part ?
Worklog click
