Whistle sound from transmission
Posted: April 28th, 2013, 6:54 pm
Ok here is the problem.
When the car is on idle there is a noise coming from transmission.Sounding like whistle or something like air leak..
When i press the clutch pedal the sound is gone,even before i reach the floor.When i release the pedal the sound is on.
Under the acceleration,in all gears,the sound is still there and changing depending the rpm.
So could it be the through out bearing or the input shaft?Or something else?
