trying to find control arm bushings
- MazdaMan1991
so i have a 94 RS, i dont want to do the escort conversion or any of that i just want to replace the control arm bushings the rear ones i think, they have the bracket around them i cant find them anywhere all i see is for the 95... idk if theyre different or what can anyone help?
My Mazdas
2008 Mazda 3 FS auto - Totaled
1994 Mazda 626 KL 5 spd - sold
2002 Mazda Millenia S - sold
1994 Mazda MX-3 RS 5 spd - bp swapped
My Worklog/Build Thread
My YouTube Page
My YouTube Page
Re: trying to find control arm bushings
The bushings in the rear lateral links and trailing arms are not available separately from the factory. You can still get replacement lateral links and trailing arms from Mazda with new bushings in them last I checked.
- MazdaMan1991
so then its probably just better to do the escort bracket swap with the energy suspension poly bushings?
My Mazdas
My YouTube Page
My YouTube Page
All new lateral links and trailing arms will cost about $500 from the dealer.
- MazdaMan1991
Yeah thats a bit pricey for me lol
My Mazdas
My YouTube Page
My YouTube Page
Actually, the rear bushing/housing from any Escort, MX-3, ZX2, Protege will fit. If you are looking for stock bushings, the Escort ones are easiest to find new. If you want to go urethane, see my post in this forum about Energy Suspension LCA bushings. viewtopic.php?f=20&t=80845 A pair of used ZX2 housings and an ES 4.3152 kit shouldn't cost more than $35-40 AND you'll have the bushings to fix the fronts of your LCAs.
Steve Seiter
Blue '92 GS, Milly square-port DE with stainless headers, Stoker100 chip, HEI/Blaster conversion,
2.25" exhaust, High flow cat, ZX-2 shocks, short shifter, urethane front bushings, 17x7s with 595 Evos
He's right. I read "rear bushing" and in my head I thought rear suspension but you're clearly talking about the rear bushing on the front Lower Control Arm.
my bad.
my bad.
Well, on the off topic and past-related note, I remember the trailing arms being about $100 each I think, but the bushings were not available separately unless you got MazdaSpeeds. I remember a few years back however the trailing arms were getting hard to get.
