Rear subframe, pre-setting the angle of the TTLs and swaybar
Posted: March 6th, 2013, 5:50 pm
by MrMazda92
Is there a "best angle" to preset the TTLs and swaybar to?
The moment you loosen the inner bolts of the TTLs the entire setup will sag in either direction. I just want to avoid stressing the bushings any more than I have to when I reinstall it.
Instinct tells me to torque the bolt down as close to the natural resting angle of the TTLs as I can, to avoid pre-loading the bushings in any direction.
Thoughts?
Re: Rear subframe, pre-setting the angle of the TTLs and swa
Posted: March 6th, 2013, 7:54 pm
by crazycanadian
The bolts should be torqued down when the suspension is at or as close ride height as possible...
Posted: March 6th, 2013, 8:57 pm
by MrMazda92
sounds perfect to me, thank you!
