V6 transmission shims partnumbers
WhiteFinish
Post by WhiteFinish »
He Guys,
I'm rebuilding my transmission but I would need some partnumbers for the shims.
There are sizes between 0.08mm and 0.7 (perhaps more, but I'm aware of these)
So far I only have 5.
G40117731B = 0.5mm
G40117732B = 0.55mm
G40117733B = 0.6mm
G40117734B = 0.65mm
G40117735B = 0.7mm
How can help me out with more partnumbers?
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
WhiteFinish
Re: V6 transmission shims partnumbers
with the help of some fellow board members
mazda Input / counter shaft shims
17180J 999635335 SHIM
T=0.35MM (Required: 001) $4.92
17180J 999635330 SHIM
T=0.3MM (Required: 001) $4.92
17180J 999635345 SHIM
T=0.45MM (Required: 001) $4.98
17180J 999635340 SHIM
T=0.4MM (Required: 001) $4.85
17180J G40117732B SHIM
T=0.55MM (Required: 001) $4.95
17180J G40117731B SHIM
T=0.5MM (Required: 001) $4.95
17180J G40117734B SHIM
T=0.65MM (Required: 001) $4.95
17180J G40117733B SHIM
T=0.6MM (Required: 001) $4.90
17180J G60117733 SHIM
T=0.75MM (Required: 001) $8.25
17180J G40117735B SHIM
T=0.7MM (Required: 001) $4.90
17180J G60117735 SHIM
T=0.85MM (Required: 001) $8.25
17180J G60117734 SHIM
T=0.8MM (Required: 001) $8.25
17180J G60117737 SHIM
T=0.95MM (Required: 001) $8.25
17180J G60117736 SHIM
T=0.9MM (Required: 001) $8.25
17180J G60117738 SHIM
T=1.0MM (Required: 001) $8.25
differential shims
27305J G00127401A SHIM
T=0.1MM (Required: 001) $4.90
27305J G00127419 SHIM
T=0.25MM (Required: 001) $4.90
27305J G00127402A SHIM
T=0.2MM (Required: 001) $4.93
27305J G00127432 SHIM
T=0.35MM (Required: 001) $4.32
27305J G00127403A SHIM
T=0.3MM (Required: 001) $4.50
27305J G00127422 SHIM
T=0.45MM (Required: 001) $4.32
27305J G00127404A SHIM
T=0.4MM (Required: 001) $4.48
27305J G00127423 SHIM
T=0.55MM (Required: 001) $4.43
27305J G00127418 SHIM
T=0.5MM (Required: 001) $7.91
27305J G00127424 SHIM
T=0.65MM (Required: 001) $4.32
27305J G00127406A SHIM
T=0.6MM (Required: 001) $4.50
27305J G00127425 SHIM
T=0.75MM (Required: 001) $4.85
27305J G00127407B SHIM
T=0.7MM (Required: 001) $4.51
27305J G00127426 SHIM
T=0.85MM (Required: 001) $4.36
27305J G00127408A SHIM
T=0.8MM (Required: 001) $4.48
27305J G00127427 SHIM
T=0.95MM (Required: 001) $4.43
27305J G00127409A SHIM
T=0.9MM (Required: 001) $4.48
27305J G00127428 SHIM
T=1.05MM (Required: 001) $4.32
27305J G00127414B SHIM
T=1.0MM (Required: 001) $4.90
27305J G00127429 SHIM
T=1.15MM (Required: 001) $4.90
27305J G00127415A SHIM
T=1.1MM (Required: 001) $4.48
27305J G00127416A SHIM
T=1.2MM (Required: 001) $4.48
Worklog click
Return to “Transmissions”
