[WTB] V6 transmission from MX6
Looking for an Item you'd like to buy? Post here.
This section is NOT for selling.
kulluminati777
Post by kulluminati777 »
Im looking for a pretty low mileage tranny from a MX6 or 626 V6.....
Last edited by kulluminati777 on December 3rd, 2012, 2:48 pm, edited 1 time in total.
MrMazda92
Re: [WTB] V6 transmission from MX6
Post by MrMazda92 »
The MX6 transmission has a different final drive, the 5th gear is the same AFAIK.
I do believe the 626 had a taller 5th though... All years of 626 have the same FD as the MX6 as well.
crazycanadian
Post by crazycanadian »
MrMazda92 wrote:The MX6 transmission has a different final drive, the 5th gear is the same AFAIK.
Mx6/626/Probe/Mx3 V6's all have the same 5th gear.. The only way to get the better 5th gear is swapping it in your self... the 626 5th gear people talk about is not from a KL transmission.. its from a different generation 4 cylinder.. the info is out there search it... The other option is a SOHC escort 5th gear.. same gear ratio as the 626 that people talk about..
626/Probe/Mx3 are said to all have the 4.38 final drive...
Mx6 are said to have the 4.10 final drive...
I don't know how far this all goes or how you can tell the difference with out tearing the transmissions apart...
I have had a BP Kia transmission apart before... From what I remember they also have a 4.10 final drive.. I believe they also run the same 28 spline axles... They have a thicker ring gear like the K motor transmissions.. You should be able to swap out the gear sets...
If you really want gas saving, you want to run an escort final drive and 5th gear... At 70mph, I am around 2500 - 2800rpm...
Mx6/626/Probe/Mx3 V6's all have the same 5th gear.. The only way to get the better 5th gear is swapping it in your self... .
My apologies crazycanadian but your info may not be accurate. There's lots of info on this subject but just to get you started kulluminati777 you can read through this post. http://www.mx-3.com/phpBB3/viewtopic.ph ... ssion+gear.
kulluminati777
Oh wow trannys are another beast all in there own. I really need to do my home work so i can get the best setup for my ZE. Thanks guys
crazycanadian
There is a lot of info... I have read various different stuff... some that contradicts one another... Its hard to sift threw whats right and whats not... I have had a bunch of the different G series various apart now, but not all of them...
That post you linked has a contradiction to something I found when pulling a probe transmission apart.. Davmac says that a probe transmission is a hybrid with 4.11's.. The one I pulled apart had 4.38's...
MrMazda92
Post by MrMazda92 »
2nd Gen Probe transmissions have the same final drive as MX-3s from the factory, at least every 2nd Gen Probe I've ever seen in person... That's only 3, from various years, but they were definitely stock.
Mx-3 and Probe are suppose to be the same
Mx-6 and 626 are suppose to be the same
I've read threads that people have found 4.10's in Probes, that there seems to be mixes and changes in the later years, unless they've been swapped earlier in their life with the other, but there's no way to know unless you do a VIN check/comparison. As they get older, more the chance than the trans/motor could of been swapped. And to know the ratio, you gotta count :S
http://www.mazdas247.com/forum/showthre ... -Gear-Swap
MrMazda92
Post by MrMazda92 »
Well, to know it exactly you do... Most people can tell the difference between the 2 by driving the car, but they wouldn't know the exact ratio... That's true.
davmac
Post by davmac »
I believe you'll get about 500 rpm reduction if you can find a mx6 or 626 tranny. You'll see here and at other sites some info on more exotic swaps, but the above is the easy route. Personally I had a smooth shifting mx3 tranny and chose to just replace the 5th gear set. FWIW I gained a 300 rpm reduction from my stock 1992 mx3 trans. Maybe someone has a set of these used for cheap, but admit I just ordered the gear set from an online Mazda parts dealer. I changed the set with the transmission in the car. You'll have to drain trans fluid and I had to drop the trans a little bit by loosening the center support bolts so the whole engine / trans sagged a bit lower. This was to allow clearance to remove the outer most trans cover to access the 5th gear set. Be safe with at least a floor jack under the center support - and of course the car itself supported by jack stands. Parts needed:
5th Gear #1
(Primary Shaft gear)
PART NUMBER - G560-17-611C
5th Gear #2
(Secondary Shaft gear)
G514-17-308
You can also replace the lock nuts:
Primary Shaft Lock Nut
F520-17-628
Secondary Shaft Lock Nut
G501-17-629A
atx_mx3
Post by atx_mx3 »
davmac wrote:I believe you'll get about 500 rpm reduction if you can find a mx6 or 626 tranny. You'll see here and at other sites some info on more exotic swaps, but the above is the easy route. Personally I had a smooth shifting mx3 tranny and chose to just replace the 5th gear set. FWIW I gained a 300 rpm reduction from my stock 1992 mx3 trans. Maybe someone has a set of these used for cheap, but admit I just ordered the gear set from an online Mazda parts dealer. I changed the set with the transmission in the car. You'll have to drain trans fluid and I had to drop the trans a little bit by loosening the center support bolts so the whole engine / trans sagged a bit lower. This was to allow clearance to remove the outer most trans cover to access the 5th gear set. Be safe with at least a floor jack under the center support - and of course the car itself supported by jack stands. Parts needed:
5th Gear #1
5th Gear #2
G514-17-308
F520-17-628
G501-17-629A
My vote: Move the Transmission Section.
Lots of good info here. Personally I like the shorter gear set MX-3 trans. I dont drive long distances(60+ miles a day) in my mx-3 and spend almost all of my time on the highway. Being able to effortlessly move through traffic without slamming it into 4th is good for me.
And on topic, the only KL chassis in the yards here in Austin are 626's. Most have TONS of miles on them. The other like chassis are all 4cly's or automajics...
1993 Mazda Mx-3 GS-Sold :(
1992 GS "The Bucket" Gone.
92 GS 5spd for sale! Sold it....after I got a hatch cover in great condition :evil:
MY WORKLOG, check it out :) viewtopic.php?f=46&t=79959
mx3_ryder
Post by mx3_ryder »
I have a 5 spd. tranny from a 93 mx3 GS with 110,000 miles on it. PM me if interested.
wagZE
Post by wagZE »
93MAZMX3KLZE wrote:I have a 5 spd. tranny from a 93 mx3 GS with 110,000 miles on it. PM me if interested.
He's not looking for an mx3 or a probe gt transmission, only mx-6 or 626.
1 mx6 88 LX auto 2.2l 4cyl
2 mx3 93 gsze bought w/ mods
4 mx3 GS SOLD-
2 pgt primered 5 spd KL SOLD
Return to “MX-3 Related Want to Buy Forum”
