HELP PLEASE, RADIATOR LEAK!!!!!!!
I need some help asap if any one would be so kind. I have a really bad leak coming from the area where the drain plug is. Its right below or above the metal area right where you unsrew the plug to drain the radiator. Can anyone tell me if they have had this problem, or give me some info if the is some type of seal or like gasket there? How much am I lookin at? Pleas Help!
Re: HELP PLEASE, RADIATOR LEAK!!!!!!!
I really need help with this, can anyone help me out?! Overnight the car probably leaks a quart or 2 is definately coming from the lower left hand portion of the radiator, below the drain plug. PLEASE HELP???????
first off, head out to an auto supply store and buy some radiator seal - there are different brands, doesn't matter much which one - it will work or it won't. no matter what, have it checked out asap by a pro, either a mechanic or a rad shop. the longer you wait, the more expensive it may get.<BR>hth
