ENERGY SUSPENSION HYPERFLEX ESCORT KIT.
Posted: October 30th, 2012, 7:55 pm
by mx3matt
so i was told a few months ago tat the escort hyperflex kit was discontinued, well i been able to locate 5 kits at $149 each.
what out of this kit is actually usuable on the mx3? front control arm bushings trailing arms, and shifter linkages?
i'm ready to pull the trigger and order these instead of the wytbushings.......
Re: ENERGY SUSPENSION HYPERFLEX ESCORT KIT.
Posted: October 30th, 2012, 8:34 pm
by MrMazda92
Which year escort components are compatible?
Google led me to this:
http://www.energysuspensionparts.com/pr ... od=4.18117
Posted: October 31st, 2012, 12:41 am
by mx3matt
that is exactly the kit i'm looking at but its $149+txs thru my supplier.
i believe the control arm bushings are compatible, my car should have the smaller rear control arm bushing as it's built in 93. i'm trying to recompile all the info and links available and i'll probably order by next week.
Posted: October 31st, 2012, 6:06 am
by MrMazda92
Where are you located? If you're stateside, you should try and purchase from the link I gave. :D
I never remember which energy bushings work and which don't... There are numerous threads, but I never remember to type out a true write-up on exactly which will work for 92-93, and 94+ MX-3s.
