not turning over
Posted: October 29th, 2012, 10:51 pm
by klmx08
So Ive got this klde I just swapped and I went to start it and im not getting anything I can hear the pump turn on when I turn the key but I get nothin the wierd part is when I turn the key back to the off postion the horn beeps...Has this happened to anyone else? Just for more info its a 96 626 engine with a 93 k8 harness kl55 ecu from a 94 626/mx6 and and a I changed the disty to a 072 (because the 96 is different) and the vaf is from the same car I got the kl55 off from..Its really weird why would I hear the pump pumping but the engine is not cranking? And why the hell does the horn beep when I shut the key off??
Re: not turning over
Posted: October 29th, 2012, 10:53 pm
by klmx08
Also I took the disty out and left the plugs plugged in and spun the rotor by hand and it was sparking..
Posted: October 30th, 2012, 6:35 pm
by davmac
Does nothing = no starter - engine does not turn over?
Troubleshoot connections to the starter especially grounds.
Posted: October 30th, 2012, 8:08 pm
by Daninski
Did the car ever have an alarm on it?
Posted: October 30th, 2012, 10:06 pm
by klmx08
davmac wrote:Does nothing = no starter - engine does not turn over?
Its funny you say that cause that was the first thing I did today I took the graound plug off and sanded the post pluged it back in and boom runing engine...but still when I turn the key off the horn does beep and before the swap it did not do that..I dont think it had a alarm on it and if that was the case wouldnt it have done it before the swap?
Posted: October 30th, 2012, 10:16 pm
by mitmaks
Maybe somehow horn contacts are exposed to ignition and when ignition is turned certain way it activates horn?
Posted: October 30th, 2012, 10:47 pm
by Daninski
mitmaks wrote:Maybe somehow horn contacts are exposed to ignition and when ignition is turned certain way it activates horn?
That nails it down.
Sorry man I was going to take a shot in the dark as well but decided to save myself the embarrassment.
Question is what receives a signal when the ignition is turned off?
Posted: November 1st, 2012, 10:37 am
by klmx08
yeah its cool any sugestions help..obviously I wouldnt be asking if I knew what it was its not really a big deal just wondering its a de going into an rs I knew there would be wrinkles to smooth out
Posted: November 2nd, 2012, 12:00 pm
by tbondo
Something must be shorting. I did a de swap into an rs and had nothing happen with the horn.
Posted: November 4th, 2012, 12:28 am
by klmx08
yeah its a little weird ill figure it out though
