steering wheel shake at 70mph
Posted: October 18th, 2012, 12:32 pm
ok. up to 60mph we're good. get to about 70mph+ and the steering wheel (ONLY the steering wheel) starts to shake quite bad.
NOW.....i let off the throttle quickly, and the shakes get VERY BAD.
NEW
passenger wheel bearing
passenger ball joint
driver/passenger cv
I replaced them based on a "visual failure". but the usual ball-joint and wheel bearing tests showed NO PLAY. everything that I have tried feels tight, including the tie rod ends.
I also tried rotating tires front to back to see if there would be a difference, and also tried taking a completely different set of wheels/tires off of a friends car. NO IMPROVEMENT.
thinking about taking it in for an alignment now, as I know for a fact that the alignment is off, just not sure how much.
could an alignment issue really cause the steering wheel/front end to shake like that at 70, and get worse when quickly letting off the throttle at that point???
NEW
driver/passenger cv
