Ok, so I'm scratching my head over a couple other items.
1--COOLING SYSTEM
So I've discovered 2 radiator caps. Based on what I found here searching, the one on the left side of the valve cover by the timing cover is the "fill cap", and the one down by the radiator is some sort of "pressure cap". What exactly is the purpose of that little "tank" by the radiator with the pressure cap on it???
Also, where do I get a replacement "filler neck" piece??? mine is cracked, and the previous owner tried to gorilla glue it. well today it started leaking on me.
![Image](http://i1185.photobucket.com/albums/z347/scorpio_vette/mx3/2012-10-07_09-44-45_449.jpg)
2--NEAR ALTERNATOR
Found a little bracket bolted to the side of the alternator, but I think it's loose, and for the life of me can't figure out what it's for. it's got a small tab on the one end like a locating tab or something that should be in a hole somewhere, and on the other end it has a little round piece (rubber). Again, I can't even imagine what it's for, and every parts store has looked at it and went "WTF is that???".
![Image](http://i1185.photobucket.com/albums/z347/scorpio_vette/mx3/2012-10-07_16-34-49_38.jpg)
![Image](http://i1185.photobucket.com/albums/z347/scorpio_vette/mx3/2012-10-07_16-34-39_6.jpg)
3--VACUUM LINES
There is a large vacuum (i think) nipple on the rear passenger side of the motor, that has a black vacuum cap on it. Any idea what goes there???
![Image](http://i1185.photobucket.com/albums/z347/scorpio_vette/mx3/2012-10-07_16-35-38_256.jpg)
There is also a vacuum line that is supposed to go to the airbox. But my car has a cold air intake on it, and so that line is just capped off. But if i'm correct, it goes to the EGR valve, or one of it's solenoids. So does that line need to be connected, or is it ok to leave it capped off??? Should I install a small air fitting into the air intake tube and hook that hose back up???
4--BRAKES
Those little wire "springs" or clips that go between the brake shoes on................oh wait.........think my brain fart just escaped and I may have just realized the answer.
Since the outer brake pad isn't attached to the caliper like on other cars, and the inner brake pad isn't clipped into the piston like on other cars, those "springs" are the only thing pushing the pads away from the rotor when the brakes are not being applied right???
On the other hand, without the brakes applied, there shouldn't really be any force on the pads, and they should be able to "move" away from the rotor just enough by themselves. So is it ok to run without those "springs", or should I buy new ones and put them in??? (some were missing and others broke)
5--TRANSMISSION
Drain plug was easy to locate. But when I went to fill it, I first noticed the "lower" fill plug, and tried filling it through there, but it didn't take very much fluid. Then after looking around, I noticed a "upper" fill plug, so I finished filling it through there. What's the point of the "lower" fill plug??? Or is that a portal to some other magical part that uses some other fluid and I shouldn't have put tranny fluid (I used gear lube)
6--SPARK PLUG WEAR (burning oil)
At the rate that I seem to be burning oil, I expected these plugs to look horrible, but from the looks of it, only one of them seems to be what I would call "wet".
What are your opinions???
They are laid out from Left to right being Passenger to Driver side, and the bottom row being closest to the radiator, and the top row being closes to the firewall.
![Image](http://i1185.photobucket.com/albums/z347/scorpio_vette/mx3/2012-10-07_17-01-11_655.jpg)
Front Plugs
![Image](http://i1185.photobucket.com/albums/z347/scorpio_vette/mx3/2012-10-07_17-01-17_410.jpg)
Rear Plugs (in my opinion, out of all 6 plugs, only the rear driver side one looks like something's wrong. what do you think???)
![Image](http://i1185.photobucket.com/albums/z347/scorpio_vette/mx3/2012-10-07_17-01-22_530.jpg)
7--SUNROOF
I went to the carwash while driving around today, to see if the car leaked any water. Well it did.......right down the driver side A-pillar trip. Seems to be coming from the Sunroof. Is that common??? What's the fix for it???
