http://www.clubprotege.com/wil/howto/hei/index.htm
but the pictures don't make it clear how to install the power tower. I think I ruined a perfectly good distributor cap.
Problems I ran into:
- I tried to drill a small hole so the screw would make contact with the metal strip in the cap. I ended up drilling a 9/64" hole, which was just barely too small.
- The screw wasn't long enough to reach to the end of the power tower. Should I have gone to the hardware store and gotten a longer screw?
- I ended up drilling a much larger hole, hoping to get the head into the cap and the "feet" of the red tower into the cap, but to no avail (I think I need a larger bit).
- What do I do with the little piece of steel wool they give me?
I read somewhere that newer cars don't have the same problem as our older ones. Is that because of coil-on-plug or did they fix the problem in the distributor? I'm thinking of going back to the stock setup, because we've had two HEI modules fail on us (after 10 grueling hours on the track). They were properly grounded and we even ran a heat sink with thermal grease (just like on a computer CPU).
