help my speedo deosnt work
jeffs93toy
Post by jeffs93toy »
So swapped the egt bp in and now my speedo doesnt work.
If it helps at all, the egt was an electronic speedo and my rs was... welll you know, cable driven.
Ryan
Re: help my speedo deosnt work
Post by Ryan »
....So why do you need help?
jeffs93toy
It doesnt work.
Need help with finding out if it matters that the speedo gear was from an f series tranny and now is in a g series, or if it is just a piece of garbage speedo gear.
Evo_Spec
Post by Evo_Spec »
jeffs93toy
a big thanks to evo once again. That did the trick.
