i've decided to go turbo. Parts that i'm using:
![Arrow :arrow:](./images/smilies/icon_arrow.gif)
so the biggest question is - ECU. I'm not buying Megasquirt or any other ECU because this is a low-budget turbo project. I'm thinking about two things - since the standart SOHC ECU recognizes GTX's AFM and drives smoothly with it (all speeds) is it possible to boost to 0.8 bar with the standart ECU?
other option - take the standart SOHC ECU and write GTX's fuel map. I have a friend who does these things but the biggest headache is where to find it (the 323 GTX B6T fuel map)?
