B&M shortshifter adjustable?
WhiteFinish
Post by WhiteFinish »
Hi Guys,
For those who are running the B&M shortshifter (or the ones who know this stuff). Is it possible to make the gab between the gears larger ?
I know the whole point of a shortshifter is to reduce the distance between gears, but the B&M is ultra short at the moment.
Just another Mx3 freak :)
Feedback topic: Click
Worklog click
Re: B&M shortshifter adjustable?
B&M only reduces it by 42%... good thing you don't have my car as I'm running a pacesetter and reduced it by almost 80% :o :shock:
Anyways, unless there is a way to move the "ball" up or down, then no you will not be able to change it (I owned a B&M and I don't believe there is a way). My recommendation would be to get a stock one to swap back in...
MrMazda92
Post by MrMazda92 »
I'd trade you a stocker straight across for your B & M! :P
RobMinhas
Post by RobMinhas »
Mooneggs wrote:B&M only reduces it by 42%... good thing you don't have my car as I'm running a pacesetter and reduced it by almost 80% :o :shock:
:shock: Adding a pacesetter short shifter to my wish list
MrMazda92
Post by MrMazda92 »
It's great, I love having one. I've adjusted the throw probably 5 times, and I finally got it to where I like it(~70% reduced)
RobMinhas
Post by RobMinhas »
I've got a BandM and I like it but if I can get the gears even closer i'll be a happy camper.
BornSticky
Post by BornSticky »
i've never done a shifter how long would u say it takes to swap out?
#5389 to join MX-3.com
Evo_Spec
Post by Evo_Spec »
BornSticky wrote:i've never done a shifter how long would u say it takes to swap out?
30 min, including the time to jack up the car and support it with jackstands.
maybe an hour if your drunk and doing it with one hand, i'd recommend not jacking up a car and going under it while drunk though, your choice.
RobMinhas
Post by RobMinhas »
30 minutes is a good estimate, I was a complete idiot and may as well have been drunk and it took me about an hour of actual labor(had difficulty making it fit) plus another hour or so of head scratching.
Return to “Transmissions”
