I'm looking for the dimensions of the stock(K8) exhaust studs, connecting the manifold to the downpipe.
If anybody randomly has some for sale, I'll consider buying them as well.
Stock exhaust studs(manifold to downpipe)
- MrMazda92
Re: Stock exhaust studs(manifold to downpipe)
cant you get them from mazda? shouldnt be too expensive...
- MrMazda92
Probably can, but I would prefer to get them this week... My local dealership never has anything in stock.
FWIW part # is 230613456
My guess (haven't measured) is these are 10M x 1.5 studs. Dorman sells those Help kits that might do the trick - try Dorman 03133. Also I've found my local Ace has most metric studs that you might need. Though it is helpful to have a stud or at least the nut in hand to confirm size and thread.
![Image](http://imageshack.us/a/img407/384/50r4.jpg)
- MrMazda92
Thanks man!
