Excessive Blow By
- 92StockMx3
Excessive Blow By
Went out to clean a bit of the engine bay and noticed the air filtered needed cleaning. So i removed the filter and the bottom was pretty soaked in oil. Took apart the rest of the intake and had oil in the MAF and into the manifold. Now i know some blow by is normal and was going to chalk it up to that and just buy a catch can. I inspected the oil to make sure thats all it was and noticed it was a little smokey, now im thinking thinking maybe my rings are going. Motor has 135k miles and has never been rebuilt. I'm going to look around and seen if i can pick up a Compression Tool and check to see the results. It's definitely not normal for that amount and consistency to be in the air intake right? This is the best picture i could get of it to show the quality. Thanks for any advice!
Mike
1992 Krylon White Mazda MX-3 RS. Cold Air Intake,17 inch Voxx rims with Toyo Proxez 4, Black Projectors, Black Taillights,Smoked Turn Signals.
1993 Brilliant Black Mazada MX-3 GS. KLZE, Short Shifter,
- Evo_Spec
Re: Excessive Blow By
that's definitely not normal, as to why it's doing it, i have no idea
- Ryan
Definitely rings. No other place for oil to blow into intake.
- Josh
I would check your PCV too, could cause issues if it is stuck open. but not that much. When turbo I would use a small fuel filter inline of the PCV to watch my blow by It would not hurt to do that in this case either.
