alright well where to start...
the mx3 car is running haltech e6k standalone on a gtr bpt. everything is wired up and hooked up. fuel injectors are setup with sequential. i have spark to plugs and im using a MSD 6a with Accel coil. using DOSbox on xp and works fine.
has spark
has fuel
pump works
timing is perfect
cranks but doesnt start.
I am running the base map for gtx that i got from atomic over on clubprotege.com. still doesnt start. ive been at it for a couple months now and my hopes are going down hill.
I would like to know this info for starters, not sure my info is correct with msd n coil
fill the blank for settings i should have.
Trigger input>
Trigger edge>
Home input>
Home edge>
then i have it on constant charge 5.0ms
Output edge>
Mike if you're available or any haltech user help me get this thing started, i just want to hear it turn over already. one step at a time.
HELP! gtr project crank/no start. HALTECH E6K
JDM MX-3 KLZE 2.5 W/ HEADERS, SHORT RAM INTAKE, FIDANZA FLYWHEEL, STAGE 3 CLUTCH, SHORT THROW SHIFTER, NOLOGY HOT WIRES, PAINTED AND POLISHED ENGINE, WHITE W/BLUE PEARL PAINT, ENKEI RPF1s 9.5lbs, COILOVERS, B-PILLAR BAR, 6K HID HEADLIGHTS, 12K HID PINK FOGS, PROSPORT GAUGES.
Re: HELP! gtr project crank/no start. HALTECH E6K
I have a basemap kicking around somewhere, just no windows XP to check
it on Halwin. I can send that to you, it has stock ignition settings and got
something silly like 38 mpg.
1994 MX-3 RS
Worklog: viewtopic.php?f=46&t=62251
B6 goodies for sale:
viewtopic.php?f=2&t=66333
2nd BP engine: http://www.clubprotege.com/forum/showthread.php?t=46695
yeah anything helps right now.
when you have time just post it or email it to me
eddiearias22@yahoo.com
