Supercharger
mazdaspeed23
Supercharger
Post by mazdaspeed23 »
So i want to go Forced induction with my klze. but im thinking more of the lines of a supercharger. the only one that i can seem to find that ppl use the most is an Eaton M62 Supercharger. As far as my searching has gone it seems that they dont make the m62 anymore.. Does anyone know of another supercharger that will fit on the ze?
Own
1994 MX-3 GS swapped ZE
1994 MX-3 GS Swapped ZE (Gone)
1996 Dodge Dakota Sport v8 Magnum
2007 Ford Fusion SE
WORK LOG: http://mx-3.com/phpBB3/viewtopic.php?f=46&t=81232
My MX-3 is nothing without me, and i am nothing without my MX-3
Ryan
Re: Supercharger
Post by Ryan »
Its forced inDuction.
Even the M62 isn't a direct bolt in, it requires and adapter plate. You'll need to find another belt driven, preferably clutched, SC that has the same general dimensions.
mazdaspeed23
Re: Supercharger
do you have any ideas for a different sc
Own
2007 Ford Fusion SE
RS_OBD'oh_2
Re: Supercharger
Post by RS_OBD'oh_2 »
there is a nice tried and true non-belt-driven-SC... I think it's called a trubo. DO IT
mazdaspeed23
Re: Supercharger
Haha
Own
2007 Ford Fusion SE
Re: Supercharger
Post by wytbishop »
Turbo >> Supercharger
Re: Supercharger
Well the m62 is used because of its size and its affordable used. My truck uses an m62 stock. I think stillens kit for the 05+ uses an m90. If you want one that's new, it'll be much more expensive. They have come out with newer tech roots chargers, you can just find the dimensions of the m62 and search the site for a new version of it, its that simple.
marcdh
Re: Supercharger
Post by marcdh »
You want to buy a new supercharger then? Look at centrifugals like rotrex, paxton, procharger etc. Or the new eaton line up. Space is tight though. You will need to relocate your oil filter if you put it where the AC would be. Take a look at my work log for m62 installation pics.
You can still pick up used m62s. They can be reconditioned. A similar option is the SC14, which again will be used.
View Worklog
weede_klze
Re: Supercharger
Post by weede_klze »
Maybe it will help you:
viewtopic.php?f=46&p=606357#p606357
Return to “Forced Induction”
