1.8 power graph
1.8 power graph
Is there anywhere I can find a power graph giving hp and torque for the 1.8 engine?
Re: 1.8 power graph
This is James' dyno, its all I could find for the K8
1994 MX-3 RS
Worklog: viewtopic.php?f=46&t=62251
B6 goodies for sale:
viewtopic.php?f=2&t=66333
2nd BP engine: http://www.clubprotege.com/forum/showthread.php?t=46695
Re: 1.8 power graph
wow thats not a bad pull for a k8. did he have any mods other then the usual intake/exhaust?
Re: 1.8 power graph
I'd say another mod was a KLDE. 139hp at the wheels, when the stock motor puts down 130bhp...doesn't add up for a NA K8. maybe he was running a 50 shot.
93 mx-3 GS (KLZE w/kl01 cams, XTD stage 3 clutch, Outlaw intake/throttle body spacers, throttle body coolant delete, headers, full 2.5" exhaust w/resonator and 40 series flowmaster, filled engine mounts)
99 silverado
99 silverado
Re: 1.8 power graph
some people have claimed 200hp to the wheels with a ze with basic bolt ons and megasquirt. i dont see how the k8 cant be any different?
- marcdh
Re: 1.8 power graph
Why do you say at the wheels? A lot of dynos in the Uk calculate/estimate flywheel horse power. Iirc it was just ihe, before he put his built engine in.
View Worklog
View Worklog
- MrMazda92
Re: 1.8 power graph
It's definitely not hard to imagine.
139 to the wheels is ~167 BHP taking a 17% loss through the drivetrain. G series trans seem closer to 15%, from what I've seen on ProbeTalk and elsewhere.
A DE in good condition would outperform that graph easily, without ANY mods.
For what it's worth, the dyno lists tire pressure... I'd assume it's a chassis dyno.
- MrMazda92
Re: 1.8 power graph
Not many bolt-on KL engines will touch 200 WHP... MegaSquirt or not. That's roughly 20% more power than the advertized 200 BHP a KL31 cam'd, Straightneck ZE with 10:1 CR puts out.
Turbo, 200 whp is easy. All motor, you're beyond the realm of bolt-ons, or you should be building race engines for a living.
- Ryan
Re: 1.8 power graph
Really?
Its a dyno plot. They are harder to get right than to fake. The curve may be close to the right shape, but the scale is almost meaningless unless you trust the person at the computer.
- MrMazda92
Re: 1.8 power graph
Another consideration that hadn't occurred to me... Thanks for pointing it out Ryan, that's valid.
