My little DD/autocross/TSD rally/ Track day car developed an odd miss fire back in December
The miss fire has been extreamly random and proven difficult to track down... I could drive the car all day long all over the city and never have a problem... Idled smooth, has lots of power.... After a lot of driving I finally narrowed down when I could get it to act up... I had to drive at a constant speed for at least 2 - 3 min, with the engine over 3000rpms... It would start out small and get worse but if I did all this I could feel the miss start and eventually get pretty bad to where the car was jerking pretty good.. It went away as soon as I romped on the throttle or if I started varying my rpms/throttle input... I have no trouble codes, and no check engine light at all...
So where would you start if this was your car??
I finally had time this weekend to bring home the lab scope from work and hook it up to my car...
Here is what I found...
(Red = CMP sensor, Green = CKP sensor from the distributor, Blue = ignition control signal from the computer, yellow = random injector current ramp)
Here is another pattern...
(Green = CKP sensor from the distributor, Blue = ignition control from the computer, Yellow = Primary ignition patter/Tach signal)
This is a zoomed in look...
(Green = CKP sensor from the distributor, Blue = ignition control signal, Yellow = primary ignition pattern)
So whats the diagnosis???... There is a slim chance my mass air flow sensor is dropping out causing the irregularities with my ignition control signal... But look closely at the dip in the ignition control signal in the zoomed in look... This dip is most likely caused by the driver in my PCM crapping out... :-\ :'( Damn... hopefully I can find a PCM for a 93-94 V6 mx6/626/Ford probe gt before friday... I am signed up to race at in the Thunderbird TSD rally next weekend...
While I was at it all I hooked up to my gf's car... It uses the same distributor and computer controls as my car and has no driavablity problems...
(Green = CKP sensor, Blue = CMP sensor, Yellow = ignition control signal)
One thing that isn't posted up that I did test was the CKP sensor down on the crank... I forgot to save the capture I had gotten... There were no irregularities with this sensor either when the motor was missing... Just for fun I also disconnected this sensor to see if it would change anything... The CKP sensor down on the crank is only used at idle or low speed for engine stability/smoothness... If I spent more time and looked at injector pulse width this is where I probably would have seen a change... Besides a slight missfire at idle the car had no problems with this sensor disconnected...
