FPR Interchangeability
Posted: February 1st, 2012, 4:34 pm
by Murdastylez15
Hi,
I have a 95 B6DE. I am in need of a junkyard FPR and while I'm at it maybe some cam seals. Would the FPR from a 92 Protege work fine with my engine? What other options do I have to grab an FPR and some cam seals from? Thanks for any help.
Re: FPR Interchangeability
Posted: February 1st, 2012, 4:46 pm
by SuperK
I'm another option for you to grab a fpr.
According to rock auto, the FPR parts guide says this:
KIA SEPHIA (1995 - 1997)
MAZDA MX-3 (1994 - 1996)
Posted: February 1st, 2012, 9:19 pm
by Murdastylez15
SuperK wrote:I'm another option for you to grab a fpr.
Thanks SuperK. I'm hoping to find a couple at Pull-a-part. Maybe even some used injectors as well. (fuel delivery issue I'm having)
Posted: February 1st, 2012, 9:36 pm
by SuperK
I also have injectors for cheap, and they were professionally cleaned, rebuilt and flowtested about a year ago.
Posted: February 1st, 2012, 10:01 pm
by Evo_Spec
Murdastylez15 wrote:What other options do I have to grab an FPR and some cam seals from? Thanks for any help.
i just want to add that if your going to get new seals, it's ALWAYS a good idea to get them new, they're so cheap that there's no need to get them used. (unless i'm interpreting your post wrong and you weren't planning on getting seals from the junkyard)
Posted: February 2nd, 2012, 7:40 am
by Murdastylez15
Evo_Spec wrote:Murdastylez15 wrote:What other options do I have to grab an FPR and some cam seals from? Thanks for any help.
I guess I shouldn't have asked the question like that, my purpose is to remove them from a junkyard car to see the difficulty in replacing them. Hoping this will fix my leak.
Posted: February 2nd, 2012, 7:45 am
by Murdastylez15
SuperK wrote:I also have injectors for cheap, and they were professionally cleaned, rebuilt and flowtested about a year ago.
Well I'm turbocharging pretty soon and I have some 323 gtx injectors that I will use.
I'm having a hesitation issue that only happens after my car runs for at least 10 mins and I turn it off and turn it back on. I'm hoping I can figure it out before I start turbocharging. The junkyard injectors are just going to be a test. Thanks though man.
