So I've read everywhere that this install is one of the easiest to do on the car........maybe since it's MY car and everything else had been difficult, I should expect no less.
So as I tried to remove the bolts, the whole nut and bolt assembly starts spinning together. So I obviously loosened the bolt somewhere, but I can't get the nut off.
But my question is, is my car safe to drive? the nuts are still on the bolt and nowhere near coming off, but just the fact that the bushings are now partially exposed and the whole bolt turns if I try to remove the nut, has me a little worried (even tho the bolt is loose, it takes a lot of strength to turn it).
Maybe I'm doing it wrong and I can actually get this finished and put back as it should be. But from what I understand, it's just removing the two bolts, slapping on the tie bar, putting the bolts back on, and I'm done.
