i remember doing my ball joint and when i bought a new one , the pin diameter was 18 mm
go to slap it on my car and i find out that mazda made 2 diff sizes 16mm and 18mm
so then i was stuck without a car till i found a 16mm ball joint
now is all good but now tie rods need to be done ,so im turning to you guys to figure out whether or not the tie rods are diff sizes just liek the ball joints before i decide to order a set
thanks guys
