Brake Fluid in driver side floor board
Posted: January 4th, 2012, 8:41 pm
by Mr.mx-3
Over the past month I have been noticing my brake fluid is staying low looked all under car for possiable leak looked inside and the driver side floor board is soaked with brake fluid it's comming from under the clutch pedal around the fire wall. What is causing this? Does this mean the clutch mastercylnder is bad?? or is it something else?
Re: Brake Fluid in driver side floor board
Posted: January 4th, 2012, 8:45 pm
by Mooneggs
I would guess the master cylinder is leaking.
Posted: January 4th, 2012, 8:57 pm
by Mr.mx-3
it's looks as though it's comming out around the shaft that screws into the pedal where you can also ajust the slack in the pedal.
Posted: January 4th, 2012, 10:20 pm
by Evo_Spec
Mooneggs wrote:I would guess the master cylinder is leaking.
+1
Posted: January 5th, 2012, 12:03 am
by Ryan
The only possible option is master cylinder. rebuild or replace.
Posted: January 5th, 2012, 12:15 am
by Mr.mx-3
Thanks I thought that was it but I needed to be sure before I go spend any money on this. BTW I have a Fidanza V-2 Sprung hub ceramic 6 puck designed for high power builds used on the street or track. Would I need any special high pressure master or stock would do. I think that may have contributed to the fail of this one I didn't have a problem untill I did my build and installed this kit and the fidanza fly.
Ok Got a new master today this is the first one I've done on a clutch do I bench bleed it before I install it or just put it in and go from there?
Posted: January 6th, 2012, 12:32 am
by mikeinaus
im not 100% sure but bench bleeding shouldnt hurt. from what ive read masters are a pain to bleed so whatever makes your life easier go for it. even if you get it partially bled its a good building point...
