Will these fit our cars?Anyone tried them?
http://www.ebay.com/itm/Energy-Suspensi ... 5647a6ffc5
Rear Trailing arm Bushings
- DeadMaker
Black Mazda Mx3 Rs 1997 B6DE
- DeepBlueMX3
Re: Rear Trailing arm Bushings
I think so, at least a a part of the kit see the link bellow with interchangeble parts(bushings)...
http://www.clubprotege.com/wil/tech/par ... bility.htm
MX-3 trailing arms and rear lateral links are different from the BG chassis. Ask the seller to measure the OD and shoulder to shoulder length of the bushings to the nearest mm and I can tell you if they will work or not. I have all the MX-3 sizing in a file at home.
- DeadMaker
Ok i have send him pm.Thank you.If they doesn't fit can i fill the mx3 bushings with 3m welding?wytbishop wrote:MX-3 trailing arms and rear lateral links are different from the BG chassis. Ask the seller to measure the OD and shoulder to shoulder length of the bushings to the nearest mm and I can tell you if they will work or not. I have all the MX-3 sizing in a file at home.
