ok, how do i get the dash off?
i checked the online shop manual and its for the newer style dash, and i have the older style. I'm trying to get to the gauges so i can install the rings that go around them, but i can't get the plastic shield off. I've removed every screw that i could find holding the dash in and it still won't come loose. any suggestions would be greatly appreciated.
Dude.
- ogtff
Re: ok, how do i get the dash off?
pull on it there are clips holding it on ![Smile :)](./images/smilies/icon_smile.gif)
from memory of another post.. there are a couple of screws right up close to the windscreen thatr you need to get to.. and I believe that you can only get them with the windscreen out.. not 100% on that one though...<P>this might help<P>@ds
- EUNOS 30X -
