Before I get the motor put in (BPT 1.8 out of a Famila GTX)
looking at upgrading amongst other things the Clutch and Flywheel,
At this stage Im pretty confident on:
Clutch Kit:
ACT Heavy Duty Clutch Kit Performance Street Disc (SS)
ZM2-HDSS
Weight 20.00 lbs
Details Torque Capacity: 245 ft/lbs; Clamp Load Increase: 33%
Price: $401.60
http://www.ultrarev.com/zm2-hdss.html
Flywheel
ACT Flywheel - Prolite
Weight 10.40 lbs
Price: $304.84
http://www.ultrarev.com/600255.html
Would this be a good combination for a relativly stock setup?
HD Clutch Kit & Flywheel for 1.8 BPT Suggestions
memphis9787
Demonic1
Re: HD Clutch Kit & Flywheel for 1.8 BPT Suggestions
OEM would be a good combination for a stock setup. You're using performance parts, they should be better.
Also, there is a transmission section.
92 RS BP05
93 GS KLZE
92 RS BP05
93 GS KLZE
