It started the other day stumbling like it wasent getting any fuel, would jerk and cut out above 4k rpm.
Next time i started it, the same only would jerk and cut out above 2k rpm and now it will hardly start or keep running
![Crying :crying:](./images/smilies/crying.gif)
The distributor is new and due to the fact that is was getting worse fast and it acted like there was no fuel in the tank, i figured the pump was bad or the filter was clogged, wasent the case! Now im beginning to think it might be the distributor anyway allthough its new!
Have a question though, tried cranking the engine with a plug on the lead holding it 5-10mm from the manifold and im getting a yellow spark, not tiny but a nice long yellow spark. Manual says "strong blue spark" So if the spark is yellow, is it too weak for normal combustion??
Maybe the coil is bad on the distributor, havent measured it yet at this time.
Any help or input on this would be greatly appreciated.
