Anyone of you feel like you just repaired the whole car?
Dark_Rider2k3
Post by Dark_Rider2k3 »
So Within the past year I've felt like I've completely repiared the whole car. To list what I've done since July 2010:
New engine
Transmission
Axles/Half shaft
Alternator
A/C Compressor
serpentine belts
Timing Belt/tensioners/water pump
Spark plugs
wires
Engine bay wiring harness
ECU
vac. hoses
shifter linkage
short shifter
clutch master/slave cylinders
clutch
flywheel
shifter fork
And then after the engine swap:
upper/lower radiator hoses
heater hoses
rear strut mounts (had already 2 years before this replaced the struts)
ball joints
tie bars
front calipers
corksport SS brake lines
replaced all brake/fuel lines
new tires
cat-back exhaust, and new flex pipe
there is probably a bit more but yeah.. I feel like in 1 year I have a whole new car lol.
anyone else have a similar story?
mitmaks
Re: Anyone of you feel like you just repaired the whole car?
Post by mitmaks »
sounds like you do have a new car, now just a paint job and it'll be mint
Dark_Rider2k3
mitmaks wrote:sounds like you do have a new car, now just a paint job and it'll be mint
you didn't see my paint job from a few years ago?
http://www.mx-3.com/phpBB3/viewtopic.php?f=1&t=71434
I do need a new front bumper though. I hit a really big racoon who decided he hated my bumper and cracked it good.
im2bad4ya
Post by im2bad4ya »
Man, I replaced those SAME EXACT THINGS (minus the hoses, tie bars, alternator and wiring harness) within the last year, and I got the transmission about 2 1/2 years ago.
But add to your list:
Springs
Struts
Strut mounts
Strut bar
E-brake cables
Brake master cylinder
Cold air intake
Radiator fan
Exhaust resonator
And this doesn't include the knicks and knacks that come with repairing a system:
(ie Cooling: thermostat, sensors. ie A/C receiver drier. ie Exhaust: O2 sesnor, etc etc)
-1992 MX-3 RS w/BP Swap Tropical Emerald Metallic "Lucky" 2005-2012 *REST IN PIECES*
Worklog: viewtopic.php?f=46&t=78176
-2003.5 MAZDASPEED Protege #882 Blazing Yellow Mica "Lemon Drop" 2012-2015 SOLD!
-2003 MAZDASPEED Protege #1186 Spicy Orange "Debbie" 2014-2015 SOLD!
-1980 Toyota Corolla Green 2014-present
-2002 Lexus IS 300 Solar Yellow 2015-present
Dark_Rider2k3
im2bad4ya wrote:Man, I replaced those SAME EXACT THINGS (minus the hoses, tie bars, alternator and wiring harness) within the last year, and I got the transmission about 2 1/2 years ago.
Springs
Struts
Strut mounts
Strut bar
E-brake cables
Cold air intake
Radiator fan
Exhaust resonator
LOL my e-brake cable was on it's way out. And the Brake booster was going to be replaced.
But the my car is in car heaven now so yeah...
im2bad4ya
Post by im2bad4ya »
yeah, I saw a prior post on that. sorry for your loss, but cars a replaceable, glad you're ok.
So you plan getting another mx3 or you gonna move on?
Dark_Rider2k3
I'm going to get a new one. Just working on a few things. Might be getting a ze mx.
MrMazda92
Post by MrMazda92 »
If we can sort shipping out in this lifetime. :lol: We'll get it figured out, there's always time to plan.
