[DIY] Under $25 PCV Catch can
mikeinaus
Post by mikeinaus »
i made a catch can today and thought id share how i did it.
first you want to find an air tight stainless/aluminum canister. thermoses work good. i grabbed a 500ml, but you could probably get away with a 350ml one if you wanted it smaller. $12 this is what i used
then your going to want 2 hose fittings. i used 1/8"x4" brass pipe connectors like this $8. you can get the ribbed ones made for hoses but i wanted it to have some depth inside the can.
and finally you want some baffling (this is optional but i suggest it). i used a stainless steel scrubber. $3
now drill 2 holes in your lid the size of your pipe connectors. i then drilled some holes into the bottom end of one of the connectors to aid in venting and prevent clogging. i also cut the 2nd connector in half to give the oil vapour some time to form before it gets sucked back into the intake. you then want to seal the connectors into the lid. i used silicone caulking but jb weld or pvc(rubber) cement should also work, it just depends what you have on hand.
now take your stainless scrubber and stretch it out so it fills the inside of the can.
now screw the cap back on and check the vacuum by sucking on one nipple while covering the other with your finger. if it holds vacuum your done. if not apply some more silicone until you get a proper seal.
youdirtyfox
Re: [DIY] Under $25 PCV Catch can
Post by youdirtyfox »
Nice effort! .... but you could of used proper hosetails and PTFE washers and avoided all that messing looking silicone :wink:
Ive seen catch cans before made out of coke bottles :lol:
Ryan
Post by Ryan »
Our FSAE team has used a 1L pop bottle for competition for a few years now....
Sigg bottle would be a good choice too. Light. Smooth. Pretty.
MrMazda92
Post by MrMazda92 »
I like it, especially since removal is fairly simple if you want to inspect it.
mitmaks
Post by mitmaks »
good idea
mikeinaus
Post by mikeinaus »
the silicone ripped when i was putting hoses on it. ive redone the seal with jb weld. looks better and should be much stronger now.
mikeinaus
Post by mikeinaus »
just in case anyone was wondering ive now driven with this for about 6months and its worked great. ive caught quite a bit of oil from entering my intake an no vacuum leaks once i sealed it with jbweld.
fowljesse
Post by fowljesse »
Good job. I don't know if you've seen my Martini shaker catch can.. I used an air/ oil separator along with the other stuff. Not a drop gets through.
fowljesse wrote:Good job. I don't know if you've seen my Martini shaker catch can.. I used an air/ oil separator along with the other stuff. Not a drop gets through.
As I recall it was shaken not stirred. :wink:
