Need to wire a push button in a 1993 v6 manual
Posted: October 4th, 2011, 9:20 pm
by Stonefly
Long story short I bought myself a 300 dollar v6 Go-kart (my mx-3). I'm not too worried about security in my area as car theft is extremely low. The previous owner fragged the ignition mechanism and after repeated starts with a screw driver the plastic is all mulched up inside. so my plan is to wire the main power to a single switch and the starter to a 60 amp push button using the original wiring. any advice before i start wire color codes would be handy... thanks in advance
Re: Need to wire a push button in a 1993 v6 manual
Posted: October 4th, 2011, 11:20 pm
by Ryan
don't set your car on fire and just use a relay.
Print out ignition wiring diagram, and go from there.
Posted: November 9th, 2011, 8:05 pm
by mikeinaus
id throw in a hidden flip switch under the dash that supplies power to the push button. that way you would have at least some kind of security. itd also give you a way to turn the car off. assuming you cant figure out how to make the push button start and stop...
Posted: December 17th, 2011, 2:32 am
by wagZE
Don't forget the starter wire is the one wire on cars that isn't fused, use a circuit breaker 12g. Minimum heavy wire & a push button switch for this application. Clutch push button switch may be bypassed aswell. Circuit breaker a must like Ryan said don't wanna burn it down.
