1996 mx3 RS - how can i make it faster?
dangerdakota
So i was wanted to know what i can upgrade to make my 1.6L 4cly RS faster without wasting my time and money with the usless 1.8L v6?
Re: 1996 mx3 RS - how can i make it faster?
I would suggest searching.
1994 MX-3 RS
Worklog: viewtopic.php?f=46&t=62251
B6 goodies for sale:
viewtopic.php?f=2&t=66333
2nd BP engine: http://www.clubprotege.com/forum/showthread.php?t=46695
- Ryan
Buying something with a 5.0L or more.
or...
a BPT swap.... built BPT swap would be better. I don't think anyone has found the limits of the crank yet, and there are 400 HP BP's out there.
or...
- RS_OBD'oh_2
you'll have issues working with the 96 RS. If you don't know what I'm talking about..... you will. Our wiring is totally different and so is the ecu. The BP swap is doable, but I think you'll have to replace your harness in order to do so.
I decided to boost mine, lots of options out there
Before you do anything, have a goal and plenty of cash.
- AaronTietje
- Ryan
If you're talking about making a motor any DECENT amount faster, the harness should be the least of your worries...
- DeadMaker
Is it true that the crank is forged?Ryan wrote:Buying something with a 5.0L or more.
or...
Black Mazda Mx3 Rs 1997 B6DE
- Ryan
The BP crank?
It is said to be made of Invincible.
- DeadMaker
Yes the bp.
Wiki says.. this engine was dubbed BP-ZE and featured a forged crankshaft.
- Josh
Umm I dont know about that... both my BP's and the 3 others I have worked on were all cast... the FE DOHC features a forged crank. I wouldn't rely on wiki too much anyone can post and correct things on it.
NA PB Crank
Not a BP but a forged crank
I guess that it may be possible for the BPZE motor to feature a forged crank but I have not found this information anywhere.
OP:
If you are only looking to add an extra 30hp+, find a B6T turbo manifold, IHI VJ14 to go with the manifold. Upgrade the injectors and Fuel pressure regulator, plumb in a front mount intercooler and call it a day. all in all should be 500 to a grand, and upward of 30 to 50 bolt on reliable WHP. The B6 will take it. you could throw on a Greddy Emanage or some kind of piggyback on there to, to maximize the output. The B6DE tends to run about 150ish to the wheels with this setup, where the B6T only yields about 135. about The wiring on the 96' isn't that bad...
NA PB Crank
OP:
B6Tdangerdakota wrote:So i was wanted to know what i can upgrade to make my 1.6L 4cly RS faster without wasting my time and money with the usless 1.8L v6?
BP
BPT
KLDE
KLZE
KLDE + Turbp
KLZE + Turbo
Best and all bolt-in options without going custom.
