Complete Torque Specs for 2.5
Posted: September 14th, 2011, 7:53 pm
Ok, I like to steal other peoples work and take the credit so here is some useful info I'll claim as my work (but really I stole it )
2.5L Torque specs (taken straight from the factory service manual)
Description - N/m - Lb/Ft - Lb/In
Oil Pan Drainplug - 29-41 - 22-30 - N/A
A/C and Generator Tensioner Lower Bolt - 19-25 - 14-18 - N/A
Crankshaft Damper Bolt - 157-166 - 116-122 - N/A
Timing Belt Cover Bolts - 8-10 - N/A - 71-88
A/C and Generator Tensioner Upper Bolt - 19-25 - 14-18 - N/A
Oil Dipstick Bolt - 8-10 - N/A - 71-88
Water Pump Pulley Bolts - 8-10 - N/A - 71-88
Auto Belt Tensioner Bolts - 19-25 - 14-18 - N/A
RH Engine Mount Nuts - 74-103 - 54-76 - N/A
RH Engine Mount Through Bolt - 67-93 - 50-68 - N/A
Water Pump Bolts - 19-25 - 14-18 - N/A
Oil Pan Bolts (large) - 19-25 - 14-18 - N/A
Oil Pan Bolts (small) - 8-10 - N/A - 71-88
Converter Inlet Pipe Nuts - 40-55 - 30-41 - N/A
Oil Pump Bolts - 19-25 - 14-18 - N/A
Power Steering Belt Tensioner Upper Bolt - 32-46 - 24-33 - N/A
Power Steering Pump Rear Bracket Bolt - 32-46 - 24-33 - N/A
Power Steering Belt Tensioner Lower Bolt - 19-25 - 14-18 - N/A
A/C Compressor Bracket-to-Engine Block Bolts - 38-51 - 28-38 - N/A
A/C Compressor-to-Bracket Bolts - 38-51 - 28-38 - N/A
Oil Strainer Bolts - 8-10 - N/A - 71-88
Oil Filter Body Bolts - 19-25 - 14-18 - N/A
Oil Cooler Shield Bolts - 8-10 - N/A - 71-88
Oil Pressure Switch - 12-17 - N/A - 104-156
Oil Cooler Nut - 25-34 - 19-25 - N/A
Oil Baffle Bolts - 19-25 - 14-18 - N/A
Fuel Rail-to-Intake Manifold Bolts - 19-25 - 14-18 - N/A
Fuel Supply and Return Line Bracket Bolts - 8-10 - N/A - 71-88
Intake Manifold Nuts and Bolts - 19-25 - 14-18 - N/A
Cylinder Head Cover Bolts - 5-8 - N/A - 44-78
Camshaft Cap Bolts - 11-14 - 8-10 - N/A
Camshaft Pulley Lock Bolts - 123-140 - 90-103 - N/A
Exhaust Manifold Insulator Bolts - 8-10 - N/A - 71-88
Exhaust Manifold Nuts and Bolts - 19-25 - 14-18 - N/A
Cylinder Head Bolts - 23-26 - 17-19 - N/A
Flywheel Bolts - 61-67 - 45-49 - N/A
Pressure Plate Bolts - 18-26 - 14-19 - N/A
Flex Plate Bolts - 61-68 - 45-50 - N/A
Rear Engine Mount Nuts - 67-93 - 50-68 - N/A
Rear Engine Mount Through Bolt - 86-116 - 63-86 - N/A
Front Engine Mount Nuts - 74-102 - 55-75 - N/A
Front Engine Mount Through Bolt - 86-116 - 63-86 - N/A
LH Engine Mount Nuts - 75-104 - 55-77 - N/A
LH Engine Mount Through Bolt - 86-116 - 63-86 - N/A
RH Engine Mount Nuts - 74-103 - 55-77 - N/A
Power Steering Pump Mounting Bolts - 31-46 - 23-34 - N/A
Extension Bar Nut (MTX) - 32-46 - 22-33 - N/A
Transaxle Shift Linkage Bolt (MTX) - 16-22 - 12-16 - N/A
Transaxle Cradle Nuts and Bolts (front mount) - 75-104 - 55-77 - N/A
Transaxle Cradle Nuts and Bolts (front and back) - 67-93 - 50-68- N/A
Transaxle Cradle Nuts and Bolts (vibration dampener) - 44-60 - 32-44 - N/A
Transverse (cross) Member Mounting Bolts - 94-126 - 69-93 - N/A
Splash Shield Bolts - 8-10 - N/A - 71-88
Wheel Lug Nuts - 89-117 - 66-86 - N/A
Fuel Rail Supply Line - 25-34 - 18-25 - N/A
Radiator Hold-Down Bolts - 8-10 - N/A - 71-88
Engine-To-Transaxle Bolts - 68-99 - 50-73 - N/A
Cooling Fan Relay Bracket Bolts - 8-10 - N/A - 71-88
Fuel Filter Nuts - 8-10 - N/A - 71-88
Fuel Line Bracket Bolts - 8-10 - N/A - 71-88
Power Steering Hose Bracket-To-Power Steering Pump Bolt - 31-46 - 23-34 - N/A
Oil Jets - 3-4 - N/A - 27-43
Crankshaft Cap Bolts - 23-25 - 17-19 - N/A
Lower Cylinder Block Bolts - 19-22 - 14-16 - N/A
Connecting Rod Cap Bolts - 22-27 - 16-19 - N/A
Knock Sensor - 20-34 - 15-25 - N/A
Valley Cover Bolts - 8-10 - N/A - 71-88
Thermostat Housing Bolts - 19-25 - 14-18 - N/A
Water Pipe Bolt - 19-25 - 14-18 - N/A
Coolant Elbow Bolts - 19-25 - 14-18 - N/A
Seal Plate Bolts - 8-10 - N/A - 71-88
No.1 Idler Pulley Bolt - 34-52 - 25-38 - N/A
No.2 Idler Pulley Bolt - 37-52 - 27-38 - N/A
Auto Belt Tensioner Pulley Bolt - 37-44 - 27-33 - N/A
Engine Mounting Bracket Bolts - 43-61 - 32-45 - N/A
Crankshaft Position (CKP) Sensor Bolts - 8-10 - N/A - 71-88
Spark Plugs - 15-22 - 11-16 - N/A
Front Lifting Eye Bolt - 19-25 - 14-18 - N/A
Rear Lifting Eye Bolt - 38-51 - 28-38 - N/A
Distributor Bolts - 19-25 - 14-18 - N/A
A/C and Generator Belt Tensioner Bracket Bolts - 19-25 - 14-18 - N/A
Generator Bolts - 37-52 - 27-38 - N/A
Oil Pump Cover Bolts - 6-9 - N/A - 52-78
