94 GS firing order
Mi|<E
94 GS firing order
Post by Mi|<E »
This doesn't seem to be like any order ive come across on the site/manuals. The damn thing
has spark fuel and air and just wont start.
Here is a pic when it was still running:
you can see the order is odd on the disty
any suggestions welcome, im getting rather annoyed at this thing
Re: 94 GS firing order
Your cap should read left to right 4,5,3 on the top and 6,1,2 on the bottom but generally speaking you just wire it up with the correct number on the disty going to the correct cylinder. Did you check that your timing belt didn't skip a few teeth? Crank it over with someone holding a timing light on the crank. Make sure TEN and Gnd is jumped in the diags box of course. :shrug:
Mi|<E
Post by Mi|<E »
Ive hooked it up according to the cap but I think the problem may be that
I flooded it, took out two of the plugs and they were soaked in gas...
whoops.
That cap looks bogus?? Do you have the original? Bottom left should be 6 then 1,2.
Mi|<E
Post by Mi|<E »
See why im a little wtf ish ?
Thats a beck arnley cap and the new replacement is the same as that one
Ryan
Post by Ryan »
The firing order is 1-2-3-4-5-6.
Look at the cap and see how the traces work inside, on most caps they cross eachother to make the order on the cap that Dan said. Some caps are different than others. Believe the cap.
That looks like a 94 cap though, do you have a 94 disty?
Mi|<E
Post by Mi|<E »
Yeah I have the 94+ disty with the three wire plug straight up and down not the
same as the larger plug.
whitete
Post by whitete »
if you lived closer i have a 94, 95 , 96 disty for sale :( other then that, that cap looks like a 94 cap though ignoition coil perhaps-- expensive part on its own though
Red96'Mx3 KL-ZE 2.5, CAI, full 2.5'' exhaust,cat delete, black stock rims polished lip, cross drilled brakes, (aftermarket bumper with halo foglights-Needs work) .
http://www.cardomain.com/id/whitete
Previous rides
Purple94' Mx3 K8-ZE CAI, Exhaust, plugs,wires
Purple95' Mx3 K8 american, CAI, Exhaust, plugs, wires,cap/rotor fuel pump, short shift,
Black 94' Mx3 i4 Stock ( hit by dear )
Mi|<E
Post by Mi|<E »
Yeah here is the disty:
whitete
Post by whitete »
Also mike is that whole unit old with new cap?? K834 on the ignition coil possibly if it is a new unit its possible its the wrong one?? I had napa mess my old one up i have a klze so my unit is kf34 hmm still trying to help ya out mike. ...
Do u hear compression in the exhaust note??
Previous rides
whitete
Post by whitete »
Also possibly take the whole unit out and inspect the inner workings very easy job did mine in 15 minutes knowing what tools i needed
3/8s ratchet 6 inch extention
12 mm or 14 mm bolts
before removal make sure to mark it so u know how to reinstall without messing timing up
only 2 bolts holding unit in place remove all wires and leads and remove unit
inspect the rotor and remove pieces inside one by one set aside in order.. Install is opposite
side note when removing cap use a 8mm socket 9/10 times ive rounded the screwdriver head.
Also when ur in there look for rust or brown metal indecation moisture has made its way to the coil then only thing stoping the car from starting
Previous rides
Mi|<E
Post by Mi|<E »
The whole unit is old with a new cap and rotor. I disassembled it and it was indeed
really rusty inside, did the best I could to clean it up and have 1.2 ohms on the 3
pin A to B (0.49-0.73 in service manual specs) and 19.3k ohms on the primary
(20-31k ohms spec) so those seem to be okay. As per the firing order again im
still not having any luck with it. I thought the cylinder fire order on V6's were
1-2-3-5-4-6 which is why they run smoother than a 4 banger. The 1-2-3-4-5-6
firing order doesn't match with the 1-2-3-5-4-6 in the 95 service manual haha....
this is just one big wtf to me.
Should I do the HEI mod then? Does this sound like that may be a good step to
take from here?
Mi|<E
Post by Mi|<E »
So the cap firing order was absolutely correct as per what Ryan said.
I put in a reman distributor and it fired right up and runs great. Just
need to time the thing and set the idle as its a bit high.
mazda915
Post by mazda915 »
i concur for hei mod .. do we all concur ... :2thumbsup:
1992 gs k8ze . 4 inch tip 2.5 cat , cold air intake ,corksport front and rear stut bars home made upper pillar bar , prosport gauges,megan racing 4 pts harnest, 10,000 K HID's , ksport suspension ,
Conan the Concur,,er agrees as well. :D
