Steering Wheel Hub
- 92StockMx3
Steering Wheel Hub
Bought a five bolt steering wheel, when i ordered the hub it was for a three bolt(older style looking) wheel. Looked around and the only company that i found that made five bolt hubs does not make one for the MX-3. Took a look at the 6 bolt compatibility list and found one car that matched (89 rx-7)so figured the 5 hole by that company should fit. Wondering if anyone has had somewhat of the same problem or either confirm/list some cars that have the same hub spline pattern. Thank you in advance.
Mike
1992 Krylon White Mazda MX-3 RS. Cold Air Intake,17 inch Voxx rims with Toyo Proxez 4, Black Projectors, Black Taillights,Smoked Turn Signals.
1993 Brilliant Black Mazada MX-3 GS. KLZE, Short Shifter,
- MrMazda92
Re: Steering Wheel Hub
No experience with this personally, but you might have to go custom.
I remember my Momo hub being in stock because it was compatible with Honda's too. As long as the spline works, why not?
- 92StockMx3
Did some searching around and found this, figured if anyone else needs it
http://cgi.ebay.com/new-steering-wheel- ... 56457b2fa3
Guess thats the answer to my question. Figure its the same as a 2inch spacer, which i think i could adapt to.
Mike
- MrMazda92
Just remember that might push the wheel back closer to your chest... If I'm correct in assuming that it doesn't replace another part of the hub.
- Evo_Spec
5 bolt steering wheels are Grant's thing, so i looked on Grant's website and they have steering hubs for 323's and protege's which i'm almost positive fit mx-3's
http://www.grantproducts.com/products/view/313/
