oil out of port #4 help..................
Posted: July 27th, 2011, 4:27 pm
by Edgar7654
i broke a cam recently and changed the cam the head gasket and timing belt put everything together[and i had smoke and over heating took the head out today and i found oil comming from exhaust #4 could it be the head gasket was installed wrong? i have only changed 4 head gaskets never had this problem or could it be something else thank you :
Re: oil out of port #4 help..................
Posted: July 27th, 2011, 4:32 pm
by burgess
o rings
Posted: July 27th, 2011, 8:49 pm
by Ryan
How much oil?
Could be a trashed valve guide...
Posted: July 29th, 2011, 11:36 am
by SuperK
Like I said before it possibly is your rings. oil can come either from the top (valves) or from the bottom (rings)
how much oil? You might be able to unplug your spark plug, shine a flashlight into the combustion chamber and crank it to find out where it's coming from. My rings were so bad, it would make a "squish" noise, then you'd see oil come from the sides.
Posted: July 31st, 2011, 8:27 pm
by Edgar7654
not alot i took my head off and i cant see anything its too little
