Need help with my KL Swap...
Posted: July 23rd, 2011, 11:55 pm
Hi Guys
I have a really strange problem with my MX-3. And no one can find the Problem. But let me explain. 4 Years ago I have swapped my K8 to a KL-DE. The first Engine had a really poor idling and had no Power... approx. 100 HP... But when the Engine was Cold i had no Problems. Full Power and no poor Idling.
So here are the Parts i have changed and checked after the Swap:
Checked the ECU fault memory ( No Faults )
Air Flow Meter
TPS
ECU from KL59 to KL07
Complete Ignition (Cables - Distributor - Sparks)
Throttle Body
Complete Intake Manifold (used)
renewed the whole Vacuum System
Checked the Catalyst
Complete VRIS System
Fuel Filter
Nothing helped so far...
So i decided to buy a whole MX-6 with only 60.000 KM
The Engine was in a very good condition (like new). The Engine had Full Power and No problems...
So i swapped the Engine into my MX-3... Now the Engine makes the same Sh*t as my old KL... Poor idling and no Power... (No Faults on the ECU)
changed a few Parts again![Wink ;)](./images/smilies/icon_wink.gif)
Fuel Pump from the MX-6
AirFlowMeter
Renewed the Engine Harness ( Distributor and MAF )
EGR from the MX-6
Changed the ECU from KL07 to KL05
Same problems... Nothing helps...
Hope you have an Idea.
Greetings from Germany
Air Flow Meter
TPS
Throttle Body
Fuel Filter
AirFlowMeter
EGR from the MX-6
