Tachometer not working after distributor change.
Murdastylez15
Post by Murdastylez15 »
Hi,
I have replaced my distributor because of some hesitation and rough idling issues. But now my tachometer isn't working. I have double checked my connectors and everything and all is connected. If there are any suggestions please feel free to share.
Thank you for your assistance in advance.
Dying to be TURBO CHARGED
Re: Tachometer not working after distributor change.
Post by wytbishop »
broken tach signal wire. Bad pin in the harness or the disty connector.
