Reverse light on all gears
Dali
Post by Dali »
Hey, the reverse light stays on in all gears forward and reverse (92 v6 manual tranny). Swapped out the sensor to see if it would go away and it still stays on. Have not had time to check the manual but does anyone know what is wrong or how to fix? Thanks, Monte.
1993 White gs klze.
_-Night-Shade-_
Re: Reverse light on all gears
Post by _-Night-Shade-_ »
Even with the switch disconnected?
I think I remember Ian having this problem, he didn't put the (enough) washers for it, so it went in too far into the trans.
MrMazda92
Post by MrMazda92 »
Did you resolve this issue?
It must be awkward at stop signs and red lights...
Return to “Transmissions”
