hey i own 2 MX3 V6 and i have the same problem with both
Posted: June 15th, 2011, 12:35 pm
by flak3dout
hi the problem i have with both me mx3s is that when the get up to opreating temp the idle starts to goo up and down on its own. It happen to my first one last summer and it made me park it for the remainder of it and i bought a new one just over amonth ago. and now this one is doing the same thing, on my first one i replace the tps and map sensor. has anyone had this problem as well if so could you help me out.
thanks
drew 92 mx3 gs v6
Re: hey i own 2 MX3 V6 and i have the same problem with bot
Posted: June 15th, 2011, 1:03 pm
by flak3dout
and it stalls after the idle surges up and down afew times and i just want to get them both fixed
http://www.cardomain.com/ride/3902748/1 ... tchback-2d
Posted: June 16th, 2011, 3:01 pm
by Daninski
Check the accordion hose going to the throttle body for cracks. This sounds like you have a vacuum leak. Check all your vac hoses and finally you may need to check your intake gaskets integrity by spraying carb cleaner/quick start or some thing similar around the base of your intake.
