KL 36 ECU Speed limiter questions.
Just got my ebay KL36 ECU in the mail today. I read that if you chop the wire in the harness that is going to pin 1M on the ECU you can deactivate the top speed limiter? My car is mechanically a 94 MX-3 GS with a straight neck KLZE in it.
My question is:
If I chop this wire will the speedo still work?, or do I need to put that wire on a switch for those um....need for speed moments?
My question is:
Dominic Toretto's whip is a MaZda and his cell phone number starts in "(323)"
My work log http://mx-3.com/phpBB3/viewtopic.php?f=46&t=72471
- _-Night-Shade-_
Re: KL 36 ECU Speed limiter questions.
Your speedo will still work.
If you read the diagram, it says the signal goes FROM the speedo TO the ECU, so the speedo gets it first from the sensor in the trans, than relays it to your ECU. If the ECU doesn't see it, it doesn't matter
Oh good, thanks guys.
- _-Night-Shade-_
When are you gonna show me your 323?
- Dragon1212
Lol Seriously one wire? wow... that is sad.
Give it up for stupid people!
Worklog for the Blue One
Worklog for the KLZE
First Car, And My baby... $550 To buy and repair from Write-off... The radio and amp that was in it was worth more than that!!!.
Hunting For a Supra MKIV, but I'll never get one. Still Hunting.
- MrMazda92
It's not necessarily sad, until people start trying to rev it to 10k and beyond.
Not being stupid is asking before cutting your wiring harness
Stupid is cutting your SPEED limiter and thinking it's your REV limiter
- _-Night-Shade-_
+1 was just about to say lolNd4SpdSe wrote:Not being stupid is asking before cutting your wiring harness
As soon as it is finished_-Night-Shade-_ wrote:When are you gonna show me your 323?
- MrMazda92
Good call.Nd4SpdSe wrote:Not being stupid is asking before cutting your wiring harness
- Dragon1212
i was referring to mazda not making it harder than that
- _-Night-Shade-_
Seeing how all the USDM ECUs don't even have limiters it's already surprising enough that Mazda put it on that one.Dragon1212 wrote:i was referring to mazda not making it harder than that
- MrMazda92
Which would be why I was like when you guys mentioned speed as opposed to rev, it didn't click that it's a KL36 until you guys replied haha._-Night-Shade-_ wrote:Seeing how all the USDM ECUs don't even have limiters it's already surprising enough that Mazda put it on that one.Dragon1212 wrote:i was referring to mazda not making it harder than that
While we are on that subject does the KL31 Have it?? just got mine 2days ago and haven't had a chance to really open it up. The car that is.
GS-ZE,fidanza fly/ 6 puck ceramic clutch,pacesetter headers/exhaust, AWR 88duro motormounts, P.R.M jetstream CAI,KYB GR-2 struts, KL31 ECU,JE-50VAF,110A Mellenia alt. S.S Corksport Clutch line.
